Can anyone explain the purpose of a Capacitor Bank? Just heard about it and never saw one used....Thanks
capacitor bank
It is used to help smooth the DC input controller voltage ripple under load.
The way I understand it: During a DC ripple the voltage fluctuates up and down quickly. The capacitor charges during the higher voltage and then discharges when the voltage goes lower and fills in the dips. The more you have in parallel (capacitor bank) the more it will hold up the voltage during a dip.ReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3 -
I wonder why Castle Creations has not designed a capaciter bank for use with their Hydra ESC's. Insted Castle recommends using atleast 8500mah batteries. In a 4s setup it would take TWO 4s 4250mah packs wired parallel to achieve this VERY HEAVY 8400mah MINIMUM rating.
Yes, the Etti will work with a Castle controller. There is nothing magic about them. I know at least one person running the Etti with a CC. He says he runs a bit cooler and has a bit more power. The ripple current works a bit like backpressure for the lack of a better way to describe it. By removing that or smoothing it out, the motor and controller work more efficiently.Don't get me startedComment
There is a fine line between "hobby" and "mental illness."Comment
While sharper minds may take issue with my reasoning here, I installed a cap bank on the UL-1 SC on my LSO mono; the reasoning is , since the SC has a fixed LVC and I need to run for 4 min in LSO, the cap bank may smooth out the downward spikes momentarily pushing the LVC below threshold. Whatever !2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
Actually the caps store energy and release it to fill in the lows, so it is not likely that you need to worry about it.
The early Spektrum radios had an issue with low voltage "brown outs" causing a lock out which due to a long re-boot time caused a few crashes. Their solution was a small cap added to the receiver to fill in the "lows" as it were. The current generation recovers faster and is less prone to brown outs, but on the early ones it was an issue which they solved with caps!Don't get me startedComment
Back to the OP's subject - I solder two additional caps onto my Castles' board to add 50% to the total 'capacity'. Quick, easy and cheap.
The real point was to illustrate what the caps do.Don't get me startedComment
