Hydro balance
you really need 4s on 5s its pulling huge amps which is killing your esc,s
even if you get a esc to handle the amps your killing your motor it pulling way to many watts
if you kill the motor while running it there is a chance you will kill the esc as well.Comment
yep just dl the FE Calc program very nice indeed!
looks like the 580L would run very nice with the y537/3 prop and pull less amps
580L 2154KV
5S1P- 5 amp
36k rpm
95.6 amps
3 min run time
est. speed 65 mph
91% efficiency
looks like i only have to keep 145 watts cool!
looks much better than the x640 prop which runs much higher amps and less efficiencyLast edited by sporthydrofan; 04-03-2010, 04:40 PM.Comment
ok the FE calc says 95 amps.... but when i put on the amp logger it runs 130 amps with this setup.... does FE have a section to input the size or weight of the boat?Comment
You need to run 4S max and buy an Esc rated for 180amps minimum with that motor. You have gone through 3 esc's so far as they were not up to the demands you subjected them to. How long do you want to run, as your setup is SAW presently.
Edit
Show us a print of your total run with your data logger
Edit
FE calc is only an estimate at best
DouggieComment
So FE is wrong?
I only blew 2 ESC's so far prop was wrong, the other ESC is fine right now it doesn't even get hot 110 Degrees F, the batteries last about 4 minutes.. im just wondering why the FE calc says 95.6amps and i got 130+ on the logger and the boat only ran 52 mph not the estimated 65mph... the motor specs says it handles up to 8S...Comment
when they say the 580 is good for 8s its they also give you a 50,000 rpm limit
which you dont want to go near.but if you ran a 6l on 8s your up around 64,000 rpm. to run 8s you would want a kv that will get you around 30,000
fe calc wont give you exact numbers and a lot depends on your setup
if setup wrong you will pull more amps etc.
the 130 amps your seeing are probably spikes not what your pulling constantly
under loadComment
A 580 8L or 9L may be better suited for 5S or 4S....lower amps and higher torque. It all depends on your run time and desired speed
DouggieComment
so going to a smaller prop wont help? i just don't have any 4Slipos.. and i have 2 brand new 5S's . it runs great now. but i was just worried about the 130 amp reading. Does FE Calc take into consideration the weight or size of the boat? does it matter?Comment
If you have two 5S, I would change the motor dependant on what you paid for the batteries. 25,000 to 29,000 rpm will give you a fast boat but not SAW speeds. Saw run times are about one minute and very hard on the wallet and equipment.
DouggieComment
i'm getting about 4 minutes of run time, i don't want saw setup i want a fast sport boat so 3-4 minutes is cool for meComment
So far all the 3 blade props I have tested I have not been happy with them.Comment
I just bought a Y536 it seems to give the most speed with the least amp load, it runs 50's now im very happythanks guys!
