Mounting my motor in the boat
  • NorthernBoater
    • 811
    I am unsure how I should mount my motor in my boot. Should I put it at an angle towards the back of the boat. Or should I put it in so it is level with the bottom of the boat
  • SJFE
    • 4735
    We will ne way more information in order to help you out. Example, hull type? lenght? type of drive? surface or submerged? size of the motor ect:)
    • saleens7
      • 1108
      put it at an angle....that way the prop (if using a fex shaft) can get as close as you can get it to the bottom of the hull and flatten out...if using a solid shaft, still put the engine at an angle and use a flex coupler to get that bend you need to flatten out the shaft as close to the bottom of the hull as you can...
      • NorthernBoater
        • 811
        Thanks for the input. I was leaning towards mounting it at an angle.
        • Doug Smock
          Moderator
          • 5272
          Whats up?
          What are you building?
          Doug
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • NorthernBoater
            • 811
            A Syncron. For now I am using a SV27 motor but I plan on putting a XL motor later on.
            http://forums.offshoreelectrics.com/...read.php?t=361
            • Doug Smock
              Moderator
              • 5272
              Cool !!
              She's looking good!!
              I just set one of those up for a buddy of mine( airplane guy):rolleyes: LOL.
              They are nice boats. We should get her wet this weekend, I'll let you know how it goes.
              Doug
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
