How to cut Carbon fiber?
  • Varooom
    • Nov 2013
    • 96
    I have a CF battery tray that I want to cut into a ESC mount and receiver mount. Don't want it to look like a hack job. What do y'all use?
    Thanks for your time,
    Varooom
  • fweasel
    master of some
    • Jul 2016
    • 4286
    Diamond coated cutoff disc on a Dremel. I like to cover the area with a piece of mashing tape so I can draw a sharp pencil line to cut along. Wear a mask, or do it outside because the fine dust is no bueno for your lungs.
    As for what I use, I also have a diamond disc in a mini table saw that I use to make long, straight cuts. A bench sander is useful to smooth edges or round off corners, but a dremel sanding drum will work well too.
    Vac-U-Tug Jr (13mph)
    • 1coopgt
      • Feb 2019
      • 414
      I also have these for my jigsaw https://www.amazon.com/Bosch-T108BHM...00CZEGY3Q?th=1
      • Varooom
        • Nov 2013
        • 96
        Thanks guys. I will do it on my back porch with a dremel cutoff wheel and a mask. The battery tray is large enough that I can make a practice cut.
        Thank you,
        Varooom
