1/4 flex cable/ stuffing tube issue
  • racerr73
    • Oct 2007
    • 133
    Hi,
    Just finished and ran for first time on weekend my U-3 1/8th scale hydroplane and after inspection of 1/4 inch flex cable, there is a burn mark about 2-3 inches on cable at coupler end. This mark lines up with support brace in hull which you can see the epoxy has got hot and started running. The boat requires a "s" bend stuffing tube due to not being able to fit the cowling on with the dummy engine in the right place. The stuffing tube is 11/32 OD with a teflon liner. The teflon line about 2 inches from couple end is softer then the rest as well due to heat.
    The question is would i get away with running a 1/4 cable in 11/32 tubing without a liner, i know 5/16th is the correct size but the last thing i want to do is remove and make a new 5/16th stuffing tube for it. Below are 3 pics showing the stuffing tube and the brace near the coupling.
    Hope you can assist me in what to do.
    Trev
  • fweasel
    master of some
    • Jul 2016
    • 4285
    What kV is the motor and what voltage are the batteries? If the RPM is reasonable, yes, I'd run that cable in the existing stuffing tube with no liner.
    Vac-U-Tug Jr (13mph)
    • racerr73
      • Oct 2007
      • 133
      The motor is a TP4070 910kv and the boat runs on 10s 6000mah packs.
      Thanks
      Trev
      • fweasel
        master of some
        • Jul 2016
        • 4285
        You'll be fine.
