Outrigger center of gravity
  • Ivan Kozyakov
    • Apr 2022
    • 81
    Hi guys!
    Where should the center of gravity be on an outrigger? I've heard different theories, but most of them are for oval racing with a turnfin. My hydro-2 outrigger is a SAW-racer and doesn't use a turnfin. How do I calculate the center of gravity for it?
  • Bande1
    • Mar 2023
    • 684
    what does it matter if its not turning? if it goes forward and doesnt plow its fine.
    • Ivan Kozyakov
      • Apr 2022
      • 81
      I like your idea because I have run out of space and there is nowhere to move the components anyway.
      Now the sponsons are at an angle of 4-5% and then the boat stopped plowing at low speeds.
      • RaceMechaniX
        • Sep 2007
        • 2821
        For SAW riggers it is a balance of lift on the front sponsons to keep the boat "floating" and enough tail weight to keep the prop hooked up. SAW riggers will typically have a more aft CG position compared to a heat race rigger. You also have to adjust front ride pad width and inclination plus prop lift. It's mostly trial and error. Took me 9 revisions of my own design to get it right.
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
        • Ivan Kozyakov
          • Apr 2022
          • 81
          Thank you. I receive a new ESC and start testing with the speedometer.
