I have some data here on my sons 1/7 scale hydo, Ml boat works hull built a few months a go. We tested the boat twice testing temps 130f and Saturday was the 1st day for racing in a local club. The boat ran really hot and burnt up that motor in first heat. I reset the strut up more to center line of the sponson like normal and he got a a 2nd motor from a member in the club to run again and the boat ended up burning that motor up as well. He was not happy. he ordered a new motor on Saturday evening and I've been all over the boat as the set up, to check water flow, running too wet and anything i can think of. Found One cooling line was tight as to what i can find and maybe causing a pinch with the cooling line at the rudder. Replacing all the cooling lines this week.
I have also been over the data on this XLX2 esc and to what i know for the past 2 days. As to Help for extra insight to additional information to the data to help narrow some issues down to avoid burning up another motor.
The Ripple is low to what i can tell that stands out. The only thing that comes to mind at least with the data, the Voltage Sag/drop at times up to 5 volts when at full acceleration. To what i do understand to a point this can affect the Amps of the system, Low volts, high amps to watts. my only thought to whats going on.
I was going to add a Castle Cap pack to The Esc to help stabilize the power flow and see what the does and data/temps as i dont see a Cap Pack on the esc , Next step was bigger MAH lipos and higher Rating. Other then that to what I'm seeing, if there any more ideas to this issue will be great thanks.
Boat information, Motor size and prop are Spec for racing class. Have to run Those for racing.
Ml boat works 1/7th Scale Newton 158/ MHR 8200, 8401, 8700 - hull
Esc Castle XLX2
Batteries, 2x CHNL 4s 90c 6200 Ran in series for 8s
Motor, 4092 850kv 8mm shaft 3000-5000 watts
1/4 flex cable
prop 5714
Esc Castle XLX2
1/4 flex cable
prop 5714
