Any cat hulls that handle like the cheetah but smaller?
Cat hull like Cheetah
The Cheetah is the best handling cat hull I've ever built/driven. It's one of the widest hulls in relation to its length. Most other hulls, larger or smaller, are considerably narrower and as a result don't turn at speed as well. Depending on the setup and speeds you're after, most other smaller hulls will be a compromise in handling characteristics.
The 28" Delta Force Pathfinder comes to mind, as do the V3 29" Proboat Miss Geico and Blackjack RTR cats.Vac-U-Tug Jr (13mph) -
I built this Aeromarine Laminates Mean Machine ( 30 inches) for a customer some time ago ; Aeromarine is a bit hard to figure out nowNice hull - wide enough to actually turn.
Maybe you can find a clean used one
https://forums.offshoreelectrics.com...OATBUILD/page3 (scroll down to post 87)
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
MTC 32" the picture with 2 front is a MTC and the back is a Cheetah IMG_0272.jpgIMG_0273.jpgIMG_0274.jpgIMG_0275.jpgIMG_0432.jpgComment
Look at Hydro Marine cats, large choice,
The Spirit of G is a great cat, two sizes : 29,5" and 39".Attached FilesComment
