Help outrigger info
  • RaceMechaniX
    • Sep 2007
    • 2833
    Upload to youtube and then post a link.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • tjsb
      • Mar 2023
      • 337
      Also how do I free up the boat, thought it was or I couldn't hit 60 mph?
      • tjsb
        • Mar 2023
        • 337
        Got a video on youtube were is the link.
        Thanks
        • tjsb
          • Mar 2023
          • 337
          • tjsb
            • Mar 2023
            • 337
            Tell me what you guys think of how its running
            • Bande1
              • Mar 2023
              • 680
              looks good dude!
              • RaceMechaniX
                • Sep 2007
                • 2833
                Good you posted the video that shows quite a bit. That prop is not working well, too much lift as you noted causing the tail to hop. That's a double ding for efficiency. Instead of pushing forward its spending too much energy lifting the tail. Second, the hopping changes the angle of attack on the front sponsons and causes the rears to make and break contact with the water. That also sucks power out. You need to get the prop/strut/AoA/turnfin correct so that on smooth water there is no bounce or chatter in the boat. Try 1616,1716, 1717 10-39 or 17-15 ABC prop.
                You want to strive for this level of smoothness:
                This is a JAE mini sprint 3S 2500mAh boat with an outrunner motor. It's butter smooth and current draw is very reasonable.
                Tyler Garrard
                • RaceMechaniX
                  • Sep 2007
                  • 2833
                  #23
                  This is a much larger 6 cell rigger, but gives a great view of stability in slight chop. This is running 77-79mph.
                  Tyler Garrard
                  • tjsb
                    • Mar 2023
                    • 337
                    #24
                    For 3750 kv on 3 cells those props are to big,even a 1614-38 was a little to big.I just ran a x640 and got to 60 mph and ran about 50% longer almost 2 minutes on a 6500 mah battery.
                    Thanks for the help
                    • tjsb
                      • Mar 2023
                      • 337
                      #25
                      Can you give what your running in that mini sprint.prop motor kv ETC?
                      • NativePaul
                        Greased Weasel
                        • 2761
                        #26
                        The Mini Sprint speed looks similar to mine unfortunately I never had good enough water to open it up and complete a run at the SAWs while i had it and it was too small for a GPS at the time, but based on looks and laptimes I think it was likely in the low 50s. Mine ran a mega 16/15/2 4200kv (28x35), on 3s 20c 1700mAh, with an uncooled castle ice lite50, spinning a detongued x432 at about 300W. This was a 6 lap sprint setup, using an old 5min 2s endurance race setup on 3s.
                        • tjsb
                          • Mar 2023
                          • 337
                          #27
                          • RaceMechaniX
                            • Sep 2007
                            • 2833
                            #28
                            Thanks for the help
                            It was not my boat, I was only filming. Ric may chime in what he was running.
                            Tyler Garrard
                            • lohring
                              • Jun 2011
                              • 183
                              #29
                              I should add a PS:
                              NAMBA runs 6 lap electric races. The only change is that everyone launches at the 30 second mark or waits on the water for a 30 second to the start signal. Boats then complete a lap to the start. Most still have enough battery to run a penalty lap if needed.
                              Lohring Miller
                              • vvviivvv
                                • May 2009
                                • 1082
                                #30
                                Bit late to the party but here is my 3s rigger designed for European style racing, 6400mah pack with a limiter, this was the first run out prior to building
                                Uk SAW record holder
