OS Lower Unit maintenance
  • nyaston
    • Apr 2024
    • 1
    In between the using of this lower unit with a brushless motor, if I don?t use it too frequently, what maintenance do I need to be doing ?
    Really appreciate it
    Thanks
  • RaceMechaniX
    • Sep 2007
    • 2833
    You should pull the stub shaft assembly out along with the cable at the end of the day and soak the cable in ATF or your preferred lube. I would do the same for the stub shaft assembly.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • racer504
      racer504
      • Jan 2008
      • 98
      Keep in mind. The the stub on an OS is a left hand thread.
      • oilumiun12
        • May 2024
        • 1
        Hello! I'm a newbie, can you explain to me why it is necessary to soak the cable in ATF or lubricant? How long do I need to soak?
        • longballlumber
          • 3132
          Letting it soak in oil allows time for the oil to penetrate into the cable widings, eliminating rusting, and increasing the life of your cable.
