114cm cat newb questions.
  • BUMBLESPECIMOODA
    • Feb 2023
    • 220
    -MYSTIC 114CM HULL.
    -4092, 2000KV MOTORS.
    -42MM 45MM 48MM PROPS.
    1. WHAT SIZE BATTERY CAPACITY ARE BOATS THIS SIZE RUNNING?
    2. WHAT THE AVERAGE RUN-TIMES?
    3. CAN BIG CAPCITY (OR PARALLEL MANY BATTERIES) WORK, WHAT ARE THE AFFECTS OF ALL THAT BATTERY WEIGHT?
    4. DOUBLE OR TRIPPLE THICKNESS MOTOR-MOUNT PLATES. CAN THAT ELIMINATE THE USE OF THE REAR MOTOR MOUNTS?
    Cheers,
  • Alex.v.Schie
    • Aug 2020
    • 35
    5000mah a 6000mah max .2x 6s each side one battery.
    Verstuurd vanaf mijn CPH2409 met Tapatalk
