Display stands
  • vvviivvv
    • May 2009
    • 1082
    Display stands
    Hello gents,
    I'm looking at ways to display some of my boat's, i have space in the garage and thinking to run a continuous counter top on the back wall which is currently unoccupied (luckily my parents have a farm for all the actual wrenching)
    Ideally i'd like to display my larger boats and maybe a couple smaller hulls
    Arrow shark have these (shame this isn't just a stand as i like them)
    Anyone have some ideas / suggestions? Would prefer to avoid wood - i.e. stainless / aluminium or CF etc.
    I"d like to display my HPR's, Mystic skater and maybe my sport hydro and a few smaller oval race boats
    Uk SAW record holder
  • NativePaul
    Greased Weasel
    • 2761
    ETTI do a couple of nice polycarbonate/carbon stands for the smaller race boats, probably wouldn't work on the bigger boats, but the end plates are just flat sheets so would be fairly simple to use the rods and fittings and make custom ends to suit what you need.
    • Panther6834
      • Apr 2020
      • 708
      The least costly...and, one of the easiest & best...ways of going about this is to make your own, from PVC tubing & pool noodle. Granted, the two images below show PVC tubing & pool noodle being used inside of a storage/transport case...but, the general idea can easily be modified into a stand.
      For the cost of buying one "manufactured" stand, your can easily build yourself 5-6 stands, if not more. Add a few dollars more, and you can "beautify" the stands with paint, to make them whatever color you want.
      ~ More peace, love, laughter, & kindness would make the world a MUCH better place
      • vvviivvv
        • May 2009
        • 1082
        Does anyone know what the clamps that make up the arrowshark units are called? honestly thinking about drawing up my own bases and having some machined out (what clamp the pipe together)
        And yes - had thought about the PVC route, would just like it to be a little more quality finish, i have quite a nice display of racing memorabilia - wings / side skirts off a le mans winning Aston martin etc
        • Panther6834
          • Apr 2020
          • 708
          Did some quick searching. Most pipe clamps are your 'usual'...but, I did find some high-quality chrome one. They're made by Gibraltar. However, they are anything but cheap...talking $23-27 per unit. Needing 12 per stand, that's approx $300 per stand just for the pipe clamps.
          • vvviivvv
            • May 2009
            • 1082
            i Think ill get one of each from arrow shark and see if i can spot weld the billet CG adjust one, they seem fairly decent value for money....
            • fweasel
              master of some
              • Jul 2016
              • 4291
              Just food for thought. Not a stand per say, more of a wall mount. My friend makes these for me out of a few pieces of wood and some foam weatherstrip. He's made them for a 60" and 72" V-bottom hull as well.
              Vac-U-Tug Jr (13mph)
              • Panther6834
                • Apr 2020
                • 708
                [ATTACH=CONFIG]178412[/ATTACH] [ATTACH=CONFIG]178411[/ATTACH]
                Gotta admit, that looks awesome. [emoji1360][emoji1360]
                Just curious...but, what prevents them from sliding/falling off? From that side-via photo, I can't see anything actually 'holding' the boat.
                • vvviivvv
                  • May 2009
                  • 1082
                  Hi fweasel,
                  If you could send some more pics of them, that would be great.
                  A few of them and the arrowshark stands would make for a great display.
                  • fweasel
                    master of some
                    • Jul 2016
                    • 4291
                    Here are the only pictures I have at the moment. The mounts for cats and hydro's is just and angles cleat. The v-bottom mounts are more of a cradle design.
                    This was a 1/8th scale mount for a Miss Budweiser hydro. Cat mount looks similar, just without the notch for the end of the front sponson
                    This is a 60" Bonzi Epic.
                    • fweasel
                      master of some
                      • Jul 2016
                      • 4291
                      This was a MHZ114
                      • monojeff
                        Moderator
                        • Nov 2010
                        • 2562
                        For big boats electric piano stands I have heard work great.
                        OSE GIFTING ELF
                        HAPPY HOLIDAYS!!
                        • T.S.Davis
                          • 6220
                          Multiple guys are using these in their trailers. Lots of adjustment possible. Looks pretty cool too.
                          Noisy person
                          • CJPB32
                            • Aug 2022
                            • 72
                            Try marine railing. A store like West Marine. Loads of s/s fittings - 90's, 45's, straight, some clamp, some use set screws, etc
