how to square flex cable/which cable?
  • Rich
    • Jan 2008
    • 551
    Hey guys I need some help. I am trying to square some .187 flex I bought here on ose. The ose cable seems to be stiffer. The cable that comes with my outboard is more flexible and seems to be a finer wire. I have a press and a die that I made to square the ends but the cable seems stiffer than the one that comes with my outboard. I am making my own cables because I am building my own lower from scratch.
    Any ideas on where I can get the finer cable or tips on squaring?
    Thanks,
    Rich
  • koen
    • Mar 2020
    • 361
    TFL has them also ,look at tfl-hobby.de you can see what they have ,then oder it from a tfl dealer near you
    • Rich
      • Jan 2008
      • 551
      Thanks for the reply Koen, it looks like they also have both left and right lay cable as well. Do you know of any distributors in the usa?
      • jkflow
        • Aug 2021
        • 329
        Might ask either one below, I'd order from aliexpress directly. Typical 2 week ship.
        No way for you to run round ones? Makes life so much simpler, I typically tin the ends, which is easy to do.
        0.187 is 4.76mm, can't tell what length you need. Below link is only as a guide, wrong diameter
        1PCS TFL 2.2/3.17/4mm Flex Cable Drive Shaft Dual Round/Square Round/Dual Square Length 300mm Spare Parts for RC Electric Boat - AliExpress
        • fweasel
          master of some
          • Jul 2016
          • 4291
          I believe square cable ends are done with a die and press, not something you'd be able to accomplish yourself in a home workshop.
          Vac-U-Tug Jr (13mph)
          • properchopper
            rcgoatbuild@snotmail.com
            • 6968
            • Rich
              • Jan 2008
              • 551
              I have a press and a die. I work in a fabrication shop. I'm just worried the stiffer cable will be problematic.
              Thanks properchopper I'll see what he can do for me.
              • properchopper
                • 6968
                OOps - Frank
                • 1coopgt
                  • Feb 2019
                  • 417
                  Did you try heating the flex cable end and heating the die before putting it in the press? Might help.
                  • Rich
                    • Jan 2008
                    • 551
                    OOps - Frank
                    Haha good thing I didn't call him yet
                    Thats not a bad idea. I might give that a try until I can call up Frank at hyperperformance.
                    • Rich
                      • Jan 2008
                      • 551
                      OOps - Frank
                      Properchopper, have you contacted Frank recently? I called him and place an order but haven't been charged yet for the cables and I have left 2 messages with no reply. Not trying to bash or complain about him just curious if he has something else going on.
                      • properchopper
                        • 6968
                        Rich,
                        Can't really say, don't know, haven't seen him at the lake for quite a while. I'll call & see what happens.
                        • Rich
                          • Jan 2008
                          • 551
                          Rich,
                          Thanks I appreciate it! I hope he's ok.
                          • Rich
                            • Jan 2008
                            • 551
                            Rich,
                            properchopper did you by chance get a hold of him?
                            • Silver954
                              • Feb 2016
                              • 69
                              The square of the cable will cause it to be stiffer. It's not a problem if straight, but if a radius is near the square end it will whip. Just something to keep in mind. The finer strand on the original helps stay flexible.
