Hi Everyone,
I live downtown Toronto (Ontario, Canada) and hence don?t get my Pursuit out much (I give that context so you can better grasp the poor judgement calls that I made [emoji4])
I took it to a cottage up north this past weekend and drove it on a day with way too much chop for a boat this size. (The only mods that I?ve applied are: a larger ESC (Seaking 180 for 6s running) and Dasboata prop.) On one speed run, the boat submarined into an oncoming wave and hit the rocky bottom (it was only 3ft? deep at that point). The nose was damaged - 1/2? crack in the topside of the hull and material removed from the gel coat and fiberglass on the bottom of the top. See pics.
I?m not sure what I should be doing to fix. I?ve seen recommendations regarding using the Bondo fiberglass repair kit or simply using epoxy on the outside and reinforcing with fiberglass or carbon inlay from the inside (if that spot can be reached). Hoping that someone can steer me in the right direction.
Little sidebar - when the boat resurfaced, it was upside down and I quickly waded out to retrieve it - with my trusty Futaba 4pv in hand. Of course, I lost my balance and plunged the transmitter into the lake. It is now disassembled and drying. An old golf adage is screaming in my ears - when you?re in trouble (deep rough, behind a tree, etc.) the one thing you don?t want to do is compound your mistake?[emoji37]
Here?s hoping that a new tx is not added to my repair costs [emoji16]
