TP motor for 6s single cheetah
  • tbonemcniel
    • Sep 2020
    • 296
    It doesn't really matter whether it's a D or Y wind. Pick the motor that's sized appropriately for you power goals and the correct kv for you voltage/prop combo. Then, if it's a D, start out with 0 deg of timing and experiment. If it's a Y, start with 5-8 deg of timing and experiment. There's no right answer for what timing is correct for a D or a Y. There are generalities that hold true, like D's typically prefer less timing than Y's, but no definitive universal answer for how much timing you should run. Run your boat with a base timing, check speed and motor temp. Increase timing, check speed and motor temp again. When either speed stops increasing, or motor temps begin increasing by a large amount, back off one timing level.
    • tjsb
      • Mar 2023
      • 326
      Will the boat run a lot faster on flat water?
      • tbonemcniel
        • Sep 2020
        • 296
        Flat water as compared to what? 1' swells? Well yeah. Some ripples? No, runs the same.
        • tjsb
          • Mar 2023
          • 326
          Thanks just trying to get it to run like it should and I'm not getting the same speed on flat water.
          • JOHN BOCCHER
            • Apr 2021
            • 12
            Hello Koen, I have a Cheetah Xl. Single motor. We have a Q cat Class at our club. I have to use either TP or the SSS 4092 V2 can motor. and run on 6s. What KV would you suggest and what amp ESC would work well. we run the 1/3 rd mile oval. Right now I have a Castle XLX2 hydro rated at 180 amp.
            Thanks for your help
            • koen
              • Mar 2020
              • 358
              for Q class a 1400kv will do and that Castle esc is about the holly grail and a SSS will pull less amps but always check temps (TP is also a good motor)
              • JOHN BOCCHER
                • Apr 2021
                • 12
                Hello Koen,
                Thanks for your reply, I appreciate all the info you and every one else have given me. It has been a great help.
