strut bearings vs strut bushing vs Teflon liner
  • paulejr
    • Mar 2023
    • 165
    Well, I had to ask , strut bearings vs bushing vs Teflon , non racing applications for sport hydro. What say ye? for 3/16 flex.
  • NativePaul
    Greased Weasel
    • 2760
    It depends what you are looking for. For max efficiency ball bearings and Teflon with oil for lube. But flex and bearings need cleaning out and re-oiling after every run, and bearings will need replacing periodically. For ease of maintenance no Teflon and a floating bushing will last nearly forever, and the shaft just needs cleaning an re-greasing every few runs or at the end of the day.
    Alternatively wire drives are the bomb as long as you don't have a tight bend.
    • paulejr
      • Mar 2023
      • 165
      Thanks Paul , good to know. If using bearings , what oil is used? 3n1 oil, gear lube, wd 40, sewing machine oil, gun oil .... on and on...
      • NativePaul
        Greased Weasel
        • 2760
        Don't use regular WD40 as a lubricant, it isn't one (though it does have some minor lubricating properties). Having said that I use WD40 branded PTFE loaded lubricant as i find the smart straw system convenient, but sewing machine or 3in1 work fine too. I haven't tried gun oil but from what i remember it is stinky stuff and probably more about corrosion resistance than lubrication.
        • TRUCKPULL
          • 2969
          Air tool oil.
          Larry
          • paulejr
            • Mar 2023
            • 165
            Huh, I would never thought that, as it is pretty thin? On parr with Marvel Mystery oil ???
            • TRUCKPULL
              • 2969
              It is a high RPM bearing oil, I use it on all my motor bearings.
              So why not use it on Ball Bering's in a strut.
              Larry
              • paulejr
                • Mar 2023
                • 165
                Indeed, some air tools hit 25k rpm ... huh. ..thanks for the tip !
