Floating Strut
  • jingalls007
    • 1015
    Floating Strut
    I’ve searched the forums with no luck; I remember seeing a couple threads that detail how to make a floating strut for a mono, but I can’t find them.
    If anyone has a link or can point me in the right direction I’d be grateful. Thanks!
  • BlakeT
    • Jan 2020
    • 536
    I have a boat that I can show you how it is done.
    • jingalls007
      • 1015
      Sounds like a plan. Thanks dude.
      • Peter A
        • Sep 2012
        • 1486
        Do you mean a flood tube?
        • jingalls007
          • 1015
          Peter, yes. I found a few more imbedded posts on the subject, but no instruction. Jesse J, I thought, started a thread on the subject but not sure.
          • Peter A
            • Sep 2012
            • 1486
            Here are a few pics from a 45" mono I did.
            • Peter A
              • Sep 2012
              • 1486
              I did it also on my Cyberstorm with a stinger.
              It is a little hard to see. However you basically glue in a tube through the transom that allows vertical movement of the stuffing tube. The inside end needs to be sealed, I usually make an aluminium cap with a hole for the stuffing tube and glue it all together when lined up.
              • jingalls007
                • 1015
                [ATTACH=CONFIG]176605[/ATTACH][ATTACH=CONFIG]176606[/ATTACH]
                Seems easy enough. I wanted to know how to seal off the end so water doesn’t get in. Just as simple as an end cap. I didn’t know you could also do it with a stinger. That’s a great idea.
                Thanks Peter!
                • RaceMechaniX
                  • Sep 2007
                  • 2821
                  I had a thread here as well: https://forums.offshoreelectrics.com...hlight=flooded
                  Tyler Garrard
                  NAMBA 639/IMPBA 20525
                  T-Hydro @ 142.94mph former WR
                  • jingalls007
                    • 1015
                    Originally posted by RaceMechaniX
                    I found that one last night! Thanks Tyler.
                    • pescador
                      • May 2009
                      • 499
                      Here?s a few pics from my Twincraft conversion I did awhile back, it?s a 2230 on 10s. I used carbon fibre for the tube and end cap.
                      Namba District 16
                      • jingalls007
                        • 1015
                        Do you prefer the flood tube to a stinger?
                        • pescador
                          • May 2009
                          • 499
                          I primarily run hydro?s so I?m more used to struts and I wasn?t sure how much adjustment I would need on the boat. Plus it was something new to try [emoji3]
                          Namba District 16
