MHZ Tsunami and Delta Force Cyber Storm 33.
  • Simmo
    • Jan 2021
    • 17
    Has anyone had experience with the MHZ Tsunami? Hull dimensions are similar to the Delta Force Cyber Storm 33 but the shape looks identical to the Delta Force DF 33. Which would be the better handling boat, not racing, just for sport. The MHZ is slightly more expensive but availability is off the shelf. Delta Force is hit and miss with availability. TIA.
  • koen
    • Mar 2020
    • 361
    if you live in europe mhz all the way ,if you live out side europe check delivery fee and customs
    • Alfa Spirit
      • 2131
      The MHZ Shockwave is a very good mono hull : https://www.mhz-powerboats.com/shop/...-635mm-25?c=66
      The MHZ Phantom is a great mono too, lenght is 98cm : https://www.mhz-powerboats.com/shop/...-versions?c=67
      The TFL Smash Shark is a very good mono, lenght is 84cm. I have a bare hull twin setup.
      • Simmo
        • Jan 2021
        • 17
        Thanks guys for the reply. I'm from Victoria Australia so shipping from Europe and the US is as much as the hull itself. I have a Delta Force DF 33 and DF 45 mark 2 which are fantastic hulls. I was looking for what's on the market in the 800 - 850mm mono range outside DF as an alternative.
        • Alfa Spirit
          • 2131
          Hydro Marine X-Ray L , 850mm : https://www.hydromarine.de/Hulls/Mon...e-WE::736.html
          Hydro Marine No Step 4 WE Mono Speedboat, 920mm : https://www.hydromarine.de/Hulls/Mon...boat::507.html
