Help with choosing solder
  • Papote611
    • Mar 2014
    • 472
    I need help choosing the right solder.
    Building a Q sport hydro with 6s batteries, to power 1470 motor,
    8mm bullet connectors.
    My question is what is everyone using to solder the connectors for high current use?
    Any help will be appreciated.
  • pescador
    • May 2009
    • 497
    A few years ago someone recommended this silver Kester and I?ve been using it ever since, it works great for me.
    Namba District 16
    • TRUCKPULL
      • 2971
      Brian - that is the same stuff that I use. It was recommended to me by Castle.
      Larry
      • Mike W
        • May 2018
        • 348
        Source?
        Otto RC Marine
        • Papote611
          • Mar 2014
          • 472
          I found this. I think it’s the same
          • Papote611
            • Mar 2014
            • 472
            Thank you Pecador for sharing.
            • jkflow
              • Aug 2021
              • 329
              Any 60/40 solder works as well.
              • Papote611
                • Mar 2014
                • 472
                Thank you. Dumb question, since lead is a soft metal, isn’t it to soft for higher current draws using a 6s setup?
                I currently use silver solder but it is hard to work with.
                • RaceMechaniX
                  • Sep 2007
                  • 2823
                  Guys, you do not need silver solder.
                  A good rosin core 60/40 electronics solder is what you want. Look for an .031-.062" diameter range which makes it easier to feed in. I would highly recommend a small 1oz bottle of liquid flux to help tin wires.
                  90% of a good solder joint is prep technique and equipment. You will want a good 80-150W iron preferably with a chisel tip, a connector pinch tool or small vise to hold connectors while soldering and a heat resistant work surface like a silicone mat or phenolic plate.
                  The most common error I see in high current joints is too much gap between the connector cup and the wire. If the wire has a loose fit in the connector try doubling the wire back on itself or balling up to make the wire fit snug. You do not want to use solder to fill large gaps.
                  Tyler Garrard
                  NAMBA 639/IMPBA 20525
                  T-Hydro @ 142.94mph former WR
                  • Papote611
                    • Mar 2014
                    • 472
                    Thank you Tyler for the info.
                    • ray schrauwen
                      • 9438
                      Come and get me coppers...
                      • jkflow
                        • Aug 2021
                        • 329
                        I use simple craft wire to fill any gap. I wrap it around the wire and solder it in place. As stated above, keep the gap to a minimum.
                        • ray schrauwen
                          • 9438
                          I just use solid copper because I have it and a lathe too. That same wire that is $7.99 USD is $16 - $30 CDN here. Our dollar is crashing, or has been for years now...
                          As long as it works use what you can!
                          • tbonemcniel
                            • Sep 2020
                            • 294
                            Oh my gosh I love the copper inserts. I take Castle wire, cut a strand off, wrap it around the wire I?m soldering and twisting it tight, then soldering the whole thing into the bullet. Haven?t lost one yet since I started doing that, but that solid copper core is awesome!
                            • ray schrauwen
                              • 9438
                              I learned it all here.
