rigger turn fin lift?
  • larryrose11
    • Jun 2010
    • 757
    Hello team.
    I have a new turn fin that came unsharpened, with both the leading and trailing edges flat.
    So, to I sharpen the interior edge, or the Exterior edge?
    The point of the turn fin is to provide just enough lift t keep the sponson out of the water
    the prop wants to push the right sponson into the water, and lift the left side.
    Most turn fins I see have the exterior edge sharpened.
    IN addition to the subtle turn fin angle adjustment,
    don't we want to approximate a Super Cavitation hydrofoil?
    If this is the case we would want the sharpened edge on the interior surface.
    in the immage below, the life points up.
    Source:
    Can anyone with experience on the matter comment?
  • RandyatBBY
    • Sep 2007
    • 3915
    Hi Larry
    I allways use the bottom of the turnfin for lift or to pull down a little if needed. This summer I built a ficture 1.75"radius and a 1"radius to keep bends the same all the time. Now I tested the new bends with riggers and Sports with different profiles. I ended up with faster speeds in turn with the P LTD Rigger and slightly less speed with the Sport. Both saw increased speeds and the rigger was the touchiest.
    Randy
    BBY Racing
    • larryrose11
      • Jun 2010
      • 757
      Originally posted by RandyatBBY
      Hi Larry
      Can you tell me about these profiles you tried?
      Was the leading edge tapered on the exterior (like the first picture in my post), or the something different?
      • RandyatBBY
        • Sep 2007
        • 3915
        I will take some pictures and get back to you.
        Randy
        BBY Racing
        • RandyatBBY
          • Sep 2007
          • 3915
          Ok the basic shapes are in paper they make all sizes of turn fins by proportionally making larger or smaller. The bends are small radius = small fin. The larger the fin the larger the raidus.
          Randy
          BBY Racing
