Proboat Shockwave 26
  • RacerX7624
    • Jul 2022
    • 10
    Boat keeps losing connection randomly when on the water.. Not sure what i should replace first and with what to troubleshoot.. Any ideas? I think this boat might be more trouble than its worth cause it has a leak under the floorboard that i cant remove without cutting the floor outImage20220722150644.jpegImage20220722150651.jpeg
  • Shadow99
    • Aug 2020
    • 14
    I?d double check the connection between the ESC & the receiver, a corroded pin can cause glitches. Some alcohol on a cotton swab does a good job of cleaning the pins.
    As far as the leak under the floorboard, your best attack would be to rough up the surface between the hull & where the shaft log exits the hull, with some sandpaper.
    Then use some epoxy putty around the shaft log & hull.
    Shadow
