50" Mono Twin setup, I need help.
  • Alfa Spirit
    • 2131
    I' ve got a mono hull, 126cm or 50" if you prefer. This mono will run with a twin setup.
    The problem is choosing the correct voltage for this hull, 2 x 6s, 2 x 10S ? What must be the max RPM unload, 30.000 or 35.000 ?
    Here is the hull :
  • koen
    • Mar 2020
    • 357
    that's a very nice hull, with a twin set up you get a very heavy hull (only the drive line is about 4.5 to 5.5 kg) but 10s and 900kv should be good and ztw 300 esc's
    • Alfa Spirit
      • 2131
      @ koen, do yo mean 2 x 10S ?
      • koen
        • Mar 2020
        • 357
        yeah because you need big motors ,to keep amps down and volts up
        • Alfa Spirit
          • 2131
          Does a 2 x 8S setup sound good for a 50" - 126cm mono ?
          Motors : TPPower 4060 (40 x 94).
          • koen
            • Mar 2020
            • 357
            8s will work in combo with 4070 or 5660 works best(in my opinion )
            • Alfa Spirit
              • 2131
              Do you know the weight of 2 x 56XX motors ? 1680 Grammes .....
              I wish I had other opinions, that would be cool.
              • koen
                • Mar 2020
                • 357
                2x5660 is 1800 but a pair of 4070 1400kv is 1300 ,SSS 4092 1400kv 1150 or you can opt for one motor also less hassle and price
                • Alfa Spirit
                  • 2131
                  • Peter A
                    • Sep 2012
                    • 1486
                    You could go with a 56 x 115/125 motor 500kv, 300A esc on 10s2P. That would allow for bigger props, even 1/4" and give good speed. You haven't said what are your goals?
                    • vvviivvv
                      • May 2009
                      • 1079
                      I run a 1.67m heavy mono on 2x 700kv lehner 3040 and 12s, does circa 70-80mph depending on props..
                      Uk SAW record holder
                      • Alfa Spirit
                        • 2131
                        My mono is 1,26 m. , not the same range.
                        • NativePaul
                          Greased Weasel
                          • 2760
                          Originally posted by Alfa Spirit
                          Quote Originally Posted by koen View Post
                          If you want something in between a long 40mm and a short 56mm motor you might want to look at the 44mm Lehner 22xx series motors.
                          • Peter A
                            • Sep 2012
                            • 1486
                            You still have not told us what are your goals? Speedfreak, cruiser, racer?
                            • Alfa Spirit
                              • 2131
                              I want a good speed for fun.
                              What do you think abour 2 x 8S , 4092 motors 1100 kV ?
