Counter-Rotating Drive System on Single Shaft
  • Meniscus
    Refuse the box exists!
    • Jul 2008
    • 3225
    Has anyone every seen, heard of, or played with a counter-rotating drive system on a single shaft? In other words, two counter-rotating props on the same shaft, one behind the other.
    Also, what pitch has been used on either prop? Including how does it affect the 2nd prop behind the first?
    Thanks for the input.
  • ChaKane
    • May 2008
    • 131
    Meniscus,
    I remember that this was discussed a little here if it helps
    http://forums.offshoreelectrics.com/...ead.php?t=5765
    • icelert
      • Dec 2007
      • 102
      The motors are out there. Not sure if anyone has applied them for boat use though. A search on RC Groups will show what they look like.
      Bryan
      • icelert
        • Dec 2007
        • 102
        Here you go
        • egneg
          • 4670
          Good question and gets the imagination going. I know they have outrunners for airplane/heli set up for this but to come up with a reliable drive system is a challenge for a boat. Maybe something like a wire drive inside a cable drive. Not sure if the outcome would be worth the effort ... except maybe the WOW factor.
          IMPBA 20481S D-12
          • Diegoboy
            • Mar 2007
            • 7244
            Here's an outdrive...
            • Meniscus
              • Jul 2008
              • 3225
              Originally posted by ChaKane
              Meniscus,
              I guess I was asleep at the wheel for this thread. I totally missed it! Thanks for the info.
              Let's just say that top speed and maneuverability does not suffer as long as you have the correct prop pair and setup. I know this much from the Spec Ops community.
              • Meniscus
                • Jul 2008
                • 3225
                How in the heck do you find this stuff Diego? LOL!
                I know how! You bribe the folks over there with promises of high volume sales in the States! LMAO!
