57" cat setup help?
  • aqwut
    • Dec 2013
    • 12
    57" cat setup help?
    Hey everyone, I am just getting back into the RC hobby and hoping to get some help finding the best hardware for this project.
    I would like to run a single motor setup on 12S if possible. Will go dual if necessary. The hull is 57" x 18" and unsure of the manufacturer. I had the boat many years ago as part of a trade.
  • koen
    • Mar 2020
    • 358
    you need a big motor (sss 56114 or TP5680 700kv with 12s)and a 300amp esc (ZTW )you can opt for a Octura strudder 8(it's gas strut/rudder)and then you have to find a prop ,start with 60mm(Prather ,ABC or octura)
    • autolex
      • Sep 2021
      • 84
      OSE Store also has some Dual Motor Mount setups to run twins on a single drive (or vice-versa) would make power delivery a bit easier. 5-7000W on a single can is a ton of heat.
      https://www.offshoreelectrics.com/pr...Assembly+Parts
      MHZ Mystic 84 (BUILD) | DYMotorshop 750mm Mono (BUILD) | BlackJack 24 of Theseus (54mph) | ProBoat JetJam (toy) (BUILD) | Noodle Recovery Scaffolding (6.6mph)
      • aqwut
        • Dec 2013
        • 12
        Thank you. I will look into it fir sure. You think with that one more I would be able to push it to 60 MPH on 16S?
        • aqwut
          • Dec 2013
          • 12
          I would like to get everything from OSE. I have already had some information from the OSE team to get started. I want to do it right as I k ow it will get expensive. What kind of speeds in optimal condition do you think I achieve with twin SSS 56114 on 12S or 16S? I honestly do not even know what hull I have. All I know is that it is 57" Cat.
          • koen
            • Mar 2020
            • 358
            if you put a sss56104 in the sponsons and run them on 8s it can be serous fast(depending the setup with is very important 80mph can be possible )you have to rebuild the inside of the hull to get space for the motors, batteries and esc's ,it's also more easy to install the stingers on the sponson if you take the wood out
