Help! Vector Sr80 Throttle in reverse mode
  • The noob guy
    • Apr 2022
    • 52
    Dont know somehow now my throttle is in reverse. I need to pull trigger to the right to get the boat run. I switched the reverse button and the boat goes full throttle without pulling a trigger. How to fix this? Cant find any manual to do this. The boat is on stock.
  • eehess81
    • Jun 2021
    • 158
    Did you do something with the throttle range settings? Can adjust that until the motor isn't spinning any more. Should be an adjuster for tx on the remote.
    • Peter A
      • Sep 2012
      • 1487
      Swap two motor leads then the motor will go the right way.
      • eehess81
        • Jun 2021
        • 158
        Switching the motor wires will definetely change the direction of the motor but then you might have to recalibrate your ESC throttle range.
