Dumas miss circus circus conversion
  • Bkclark70
    • Apr 2022
    • 3
    Looking to change out my nitro set up to electric. Not willing to loose any speed. Anyone have any suggestions about electric motor/ ESC/ prop to convert to that will keep me in the 65 to 70 MPH range.
    Boat is 43 inches long and weights in around 5 lbs without hardware
  • 1coopgt
    • Feb 2019
    • 414
    You're probably gonna want to go with a 250 to 300a esc . I'm slowly build Miss Elam and using a NEU 1527 1.5Y 850 kv Motor. I'll be running 2 4s packs in series or maybe 2 5s packs . So 8 to 10s.
    • Bkclark70
      • Apr 2022
      • 3
      So you think the NEU 1527 running on 8 - 10s would be capable of speeds up to 60-70 mph
      • photohoward1
        • 1610
        Proven set-up. Yes.
        • Bkclark70
          • Apr 2022
          • 3
          Last hopefully not stupid question. Can I use all existing running hardware and drive shaft from the nitro set up
          • 1coopgt
            • Feb 2019
            • 414
            Sorry don't know what hardware your boat has.
            • jaike5
              • Dec 2011
              • 561
              Yes you can. Line up motor mount and motor to stuffing tube, and correct coupler for motor and cable.
              J.
              • RossCo216
                • May 2020
                • 20
                Make sure you check the COG in the boat before the build swap and use that as a guide when fitting the electric motor and batteries.
                • markman660
                  • Apr 2020
                  • 4
                  I’m still working on my first build of Fast Electric 1/8 scale hydro so I’m a newbie when it comes to hardware but for converting from nitro to electric I can recommend two videos provided by M5 Performance Hydroplanes – Scott Meyers.
                  RC Nitro to Electric Conversion Part 1 – You Can Do It!
                  Nitro to Electric RC Hydroplane | Electro Eliminator Part Deux
                  Mark Vanyo
                  Renton, Washington
                  • incidentslide
                    • Feb 2023
                    • 3
                    The transmitter and receiver for both nitro and electric RC vehicles are the same. As a result, you won't have to update them.
                    • llemons68
                      • Feb 2023
                      • 1
                      Thank you! I thought these two vehicles needed to have 2 different transmitters and receivers but I was wrong 2 player games.
