55inch fireboat mono deep V plywood hull
  • Jalopy
    • Oct 2021
    • 15
    want to know how to get my boat to go in reverse Radio is a Fly Sky FS-i6X ,ESC ZTW Seal 200A and ZTW LCD Program card
  • 1coopgt
    • Feb 2019
    • 417
    Did you read the instructions for your esc? That would be the first thing I would look at or find a video on programing your esc.
    • Peter A
      • Sep 2012
      • 1488
      That's interesting, the seal esc's have reverse that you cannot turn off. If you are using a sprung self centering throttle it should go in reverse if you move the stick or trigger to reverse.
      • 1coopgt
        • Feb 2019
        • 417
        Guess the next question should be what radio are you using?
        • Alfa Spirit
          • 2131
          • Peter A
            • Sep 2012
            • 1488
            I use the same radio. If you have the left stick self centering (mode 1?) then it will work with reverse. Make sure your trims, including sub trim are zeroed before calibrating.
