Rudder length question
  • zooma
    Local club FE racer
    • May 2014
    • 652
    Is there any rule-of-thumb for determining a good rudder length (depth) on a mono hull? I guess that I'm looking for the least resistance (thus best speed) without losing stability or steering.
    Also, regarding rudder bracket length, is it better to have the leading edge ahead of the prop, alongside of the prop, or behind the prop?
    Ron - The Villages, FL
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7116
    So what particular mono are you asking about?
    Length: buy two, slowly cut the first down in til too short. Then cut the second one almost as much
    Setback: depends. Hull, application, driving style.
    Sorry no rules of thumb on a generic hull question.
    "Look good doin' it"
    See the fleet
    • zooma
      Local club FE racer
      • May 2014
      • 652
      Thanks. Just trying to avoid trial-and-error, and sacrificing one rudder. Might do this someday.
      Regarding setback: All of my boats are deep vee mono's for oval racing. P-lim is an OSE Raider, P is a Dominator, and Q is a Delta Force 45 Mk 2.
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7116
        As far as setback, I generally start with leading edge of rudder a drive dog.. but certain hulls or driving styles may want it farther back.
        You really want your rudder as short as feasibly possible. And it also depends on weight distribution and strut height. So many variables, it makes rules of thumb pretty sloppy.
        See the fleet
        • Alfa Spirit
          • 2131
          Stinger lenght is 1/10 of hull lenght, the rudder lenght is +30mm than the V hull, look
          • Jesse J
            scale FE racer
            • Aug 2008
            • 7116
            Deleted..Forgot to ignore..
            See the fleet
            • dasboata
              • Dec 2010
              • 3152
              1-1/2-2 inch below the tip of the prop as a rule of thumb
              • Alfa Spirit
                • 2131
                Keep cool papy. Total stinger lenght, propeller included is 1/10 of hull lenght.
                For the blade it must be 2 or 3 cm under the V.
                • zooma
                  Local club FE racer
                  • May 2014
                  • 652
                  Thanks guys.
