Leopard motor help
  • RC LOVER
    NAMBA # 850
    • Aug 2020
    • 10
    Leopard motor help
    What would be the most powerful/fastest 4092 Leopard motor for a 44" Tunnel hull using a 300 amp ESC--I have been looking at the 930kv and 700kv--Am i looking at the correct KV area? Thank you for your Help.
  • tbonemcniel
    • Sep 2020
    • 296
    They make the same power. The rpm they spin at is different. You would base the kv on the rpm you plan to spin the prop.
    • RC LOVER
      NAMBA # 850
      • Aug 2020
      • 10
      Hello, With a tunnel hull i would think 25,000 to 30,000?
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7116
        What voltage? 8s-10s? Application? Racing, straightline, or what? Need some context please.
        "Look good doin' it"
        See the fleet
        • RC LOVER
          NAMBA # 850
          • Aug 2020
          • 10
          10S -- Straight line-- Some Racing
          • jkflow
            • Aug 2021
            • 329
            Easy to calculate
            3.8V per cell, 12 cells and 700rpm or 930 rpm per V.
            3.8*12*700=~31000rpm
            *930 = ~42000 rpm
            Subtract ~ 10% of the rpm for loss etc, and you are pretty close.
            • Alfa Spirit
              • 2131
              Single motor setup = 10S or 12S battery.
              10S = 950kV motor.
              12S = 780kV motor.
              • HTVboats
                • Jun 2011
                • 803
                On 12S with a 44" tunnel and the weight of batteries a 4092 will be marginal for big straightaway speeds. That said stay low on KV's 800 or less and you have the leverage to turn the larger props needed to push the hull. JMO
                Mic
                Mic Halbrehder
                IMPBA 8656
                NAMBA 1414
                • RC LOVER
                  NAMBA # 850
                  • Aug 2020
                  • 10
                  Wanted to go 10S
                  • HTVboats
                    • Jun 2011
                    • 803
                    10S 1000kv or less
                    Mic Halbrehder
                    IMPBA 8656
                    NAMBA 1414
                    • tbonemcniel
                      • Sep 2020
                      • 296
                      Like mentioned, I would run a bigger can than a 4092 for a 44" anything. That's typically 56mm motor territory if you want to be fast.
                      • RC LOVER
                        NAMBA # 850
                        • Aug 2020
                        • 10
                        I do not think there is a lower unit and adapter that will take a 56mm Electric motor. That is why i am asking about the 2 most powerful 40mm Leopards.
                        • HTVboats
                          • Jun 2011
                          • 803
                          A K&B lower and .187 flex won't take much more than a 4092 motor. You could go with twin outboards and 4082's
                          Mic
                          Mic Halbrehder
                          IMPBA 8656
                          NAMBA 1414
                          • RC LOVER
                            NAMBA # 850
                            • Aug 2020
                            • 10
                            No Twin Motors
                            • Speed3
                              • Mar 2017
                              • 371
                              The 930kv on 8s with an octura x450 should pull somewhere around 75 amps.
                              That would give good runtimes. Hopefully an x450 would be enough diameter for that boat.
                              The graupner k series props will pull less amps that the octuras. So maybe a k series 55mm is another prop you can try.
