Hydropro Inception problem
  • Bart Marshall
    • 27
    Bought a new one last summer and I could only get 43 mph. Used 2 3cell lipo batteries that take my Spartan over 50 mph. It's winter here in MN put I thoufgt I would check if transmitter and receiver were binding correctly. When I plug everything in I get 5 quick beeps-then a pause followed by 2 more beeps. Everything seems to work correctly but the manual states it should be only 3 beeps-not 7 beeps. Any help would be great. Unrelated-this boot does not have reverse does it-mine does not.
  • jkflow
    • Aug 2021
    • 329
    Do a throttle range adjust per ESC manual linked below, they should have added it to the normal manual. Make sure that throttle trim is at zero before you start and to always leave it at zero.
    You can also program forward/reverse, just be aware that going reverse will potentially damage your shaft.
    • 1coopgt
      • Feb 2019
      • 417
      Are the Batteries in series or parallel 6s vs 3s? 2 different boats 2 different motor/esc combinations also. Have a feeling its the differences in the boats.
      • jkflow
        • Aug 2021
        • 329
        They are in series just like the Stealth. Mine runs around 48mph.
        Might check your strut angle and trim tabs. Not that everything is fighting each other.
        Do the throttle adjust first.
        • Bart Marshall
          • 27
          Thanks-I will do the throttle adjust. Do you get 3 beeps when you plug in your batteries-or are the 7 beeps I get normal?
          • jkflow
            • Aug 2021
            • 329
            The manual is plain wrong on this detail.
            You get 1 beep per 'S' i.e. I get 6 beeps followed by 2. The 2 is slightly different and only means it's ready to go.
            You can never get 3 beeps. If you are truly getting 5, you have an issue with your batteries. I'm almost certain that you miscounted, they go fast.
            • Chowning2
              • May 2021
              • 2
              You should get 6 fast beeps and then a single beep if all is correct. I get 54mph bone stock outta mine. Its the newer inception release.
