Zonda SSS 3674 2075 KV or TP3650 1700kv
  • MidKnight
    • Aug 2021
    • 29
    For the twin cat Zonda, i have the SSS 3674 2075kv that came with it, that i took out and placed the TP3650 1700kv in, which i get 83MPH. Do you think ill be better off with the stock SSS motors?
  • Johnc
    • Aug 2015
    • 199
    Well,
    I'm running stock motors (sss 3674-2075kv on 6s) changed to 180a ESC with props 1716 props from dashbota and pushing around 100+ (depending on weather conditions) Oh, mine is all CF as well.
    Still trying to get close to madracer's speed lol (he's here on the forums occasionally)
    Check with Chris (dashbota) on what good props would be good with 1700kv motors.
    • MidKnight
      • Aug 2021
      • 29
      i also run 180 seaking, and dashbota probs (geico 1), mines the FG hull
      • fweasel
        master of some
        • Jul 2016
        • 4291
        Depends what you want out of the boat. You're turning fewer RPM's with the TP motors, running more efficient, cooler, and longer run times. The SSS motors will no doubt be faster, all things else equal, with shorter run times and more heat.
        Vac-U-Tug Jr (13mph)
        • koen
          • Mar 2020
          • 361
          With 1700kv depending how much speed you want you can go for bigger props (ABC 1816-17 or 1915-17) you will be faster ,but you have to keep watching temps (check Dasboata)
