I really f'd up today! Totally cracked my rear stern
  • boredom.is.me
    • Jun 2009
    • 595
    The thicker the material is, the heavier the texture is going to be. When starting from scratch, you start with a thinner cloth for finer detail. This thinner layer is the exterior layer you see. If you're using carbon fiber cloth on the outside, you have a lot to work down. (I'm guessing you used 3k cloth.) This will more than likely break the fibers which really defeats the purpose of using carbon fiber. It was definitely a better option to place it inside the hull. You either need to apply a few thin layers of glass that you can sand down, or.....start sanding.
    • mrd72
      • Oct 2021
      • 70
      just a little update, finally got to put some paint down, little wet sanding, think im going to lay a strip of vinyl pinstrip to hide the transition of the repair then clear coat over everything. Definitely patients is key im learning.1C0DEE7E-6696-4C3A-98FB-88F567FFA510.jpg
      • mrd72
        • Oct 2021
        • 70
        ok, did the clear coat, ill wait a fee days and i’ll attach all the hardware, have to decide to use a nylon shear screw on the rudder or not, obviously the screw thats there didnt help avoiding this whole mess.
        • mrd72
          • Oct 2021
          • 70
          all back together and took it for a spin, ran great no issues thank god. Ran it for about 5 minutes, is it true that if you run it partial throttle mixed with a little full throttle puts mote strain on ESC then just running it at full throttle the whole time?
          • mrd72
            • Oct 2021
            • 70
            all back together and took it for a spin, ran great no issues thank god. Ran it for about 5 minutes, is it true that if you run it partial throttle mixed with a little full throttle puts mote strain on ESC then just running it at full throttle the whole time?832F9990-7EFB-4689-84BD-DD475709C4E8.jpg
            • Mike W
              • May 2018
              • 348
              That is true. The more power the ESC is holding back the more heat it generates. If you are running in rough water prop down.
              Excellent repair work!
              Otto RC Marine
