reading a data Logging
  • dasboata
    • Dec 2010
    • 3152
    Originally posted by TRUCKPULL
    Chris - are you looking for a SAW setup or for Oval racing?
    Larry
    A couple passes Larry
    • TRUCKPULL
      • 2969
      Sorry - my setup is for Oval Racing - my boat speed is around 75Mph.
      Larry
      • jkflow
        • Aug 2021
        • 329
        Ron - upload your log file and I can take a look.
        Let me know if you are looking for something specific or general info.
        • jkflow
          • Aug 2021
          • 329
          Excellent tutorial on the data log. Keep in mind this is a video for car speed runners but 90% is still applicable.
          • dasboata
            • Dec 2010
            • 3152
            this is what I got when I hit save , it's not the graph
            • jkflow
              • Aug 2021
              • 329
              Yes, that is a comma delimited file for use in Excel or the castle data viewer.
              You need to download the Castle Link software. When installed, you get an additional program called Castle Link Graph view.
              This only works in Windows, not on Mac.
              Open Castle Link and go to 'Graph Viewer (Castle1.jpg)
              In the Graph viewer, select Load data (Castle2.jpg)
              If you're in the graph view, just draw a box around the area of interest and that is how you zoom in.
              I do not recommend loading this data in excel or other spreadsheets, just a lot to deal with.
              • TRUCKPULL
                • 2969
                That Ripple voltage is way too high.
                Better put some extra caps on that ESC,
                Larry
                • jkflow
                  • Aug 2021
                  • 329
                  #23
                  Not disagreeing with the ripple, but there are all kinds of issues in this log.
                  Throttle command is not getting to the ESC with partial total blackout.
                  ESC is not calibrated correctly, max power is barely at 70%. I bet that is because of the bad throttle command.
                  All that alone can cause crazy ripple voltages.
                  I would make one change at a time, fix the y-cable issue, recalibrate and do a clean run to look at the log again.
                  • zooma
                    Local club FE racer
                    • May 2014
                    • 652
                    #24
                    Thanks, but I am not the one with the problem. I just keep a bunch of these files on my hard drive for performance comparisons.
                    Ron - The Villages, FL
                    • dasboata
                      • Dec 2010
                      • 3152
                      #25
                      [ATTACH=CONFIG]173892[/ATTACH][ATTACH=CONFIG]173893[/ATTACH][ATTACH=CONFIG]173894[/ATTACH]
                      yes I do have the graft viewer and from there is when I hit save file ,, it went to the excel spread sheet it ok for now , I sent the ESC out and I'm going to 1650 KV and made a new y connector and when I get the ESC back and the new motors I will test and revive this tread , I really appreciate the hep PM me if you need anything thanks to all you guy !!!
