Which TP motor should i buy !
  • Andris Golts
    • Jan 2011
    • 504
    Hi all i am in the process of starting to build a ML boat works FE 34 inch Wild thing mono hull .I would like to set this boat up using 6S power i have a Swordfish pro 220 amp esc with 6 mm bullet plugs . What size TP motor and KV range would be most suited for this application . Regards Andris Golts .
  • Peter A
    • Sep 2012
    • 1489
    TP 4050 1570 kv, it can get you at 100kph range with a 45-47 mm prop. I have run one in my DF Pirate 35" at those speeds.
    • properchopper
      rcgoatbuild@snotmail.com
      • 6968
      Andris - to come up with a sensible package (as in building a sprint racer that can go mill + 6 +1 ) on a 1/6 mile course I'd adhere to the good old chart for KV vs Voltage.* To keep your 6S rpm in the "golden comfort range" a TP Power 4050 5Y [1330 kV ] will yield @29500 at the prop unloaded. Nice handling in the 50 mph range. The TP Power 4060 4Y [1350 KV ] will yield @ 29,900 at the prop unloaded and will pull lots of prop to get you up around the 60's.
      • Andris Golts
        • Jan 2011
        • 504
        Thanks Peter A and properchopper for the excellent information. Regards Andris Golts.
        • Alfa Spirit
          • 2131
          4060 motor is big and heavy (34" hull) , prefer a 4040 (40mm x 74mm) TPPower motor 1500kV to 1700kV with a 6S setup.
          • HTVboats
            • Jun 2011
            • 803
            A 4050 - 82mm length would be on the ragged edge but manageable. 1400-1600kv for sure. We have guys using 4040 74mm length motors for our Q limited racing running high 50's easily. A great match for a 34" hull with longer run times. 120-140 amps on 6S.
            Mic
            Mic Halbrehder
            IMPBA 8656
            NAMBA 1414
            • RaceMechaniX
              • Sep 2007
              • 2833
              Take Tony's advice. If you plan on running a heavier 2P setup the 4060 is the way to go. If you run a lighter weight 1P setup go with the 4050. I would stick to the lower end of the KV range. 1200-1400 will allow 44-50mm props.
              Tyler Garrard
              NAMBA 639/IMPBA 20525
              T-Hydro @ 142.94mph former WR
              • Troy1957
                • Jun 2022
                • 27
                Max amps on a 4060 1350 kv is 163 according to TP Power website.. Props that will stay under that and get 60+ mph????
                • Peter A
                  • Sep 2012
                  • 1489
                  I run that TP motor in my Q hydro. We have a max limit of 6000mah for the class here. It runs around 65 mph on an ABC 1915/45/17 prop. I can do a heat race on 5500mah batts like this.
                  I tried also the TP4050 1570 motor in the same boat with an ABC 1814/45/17 and managed 70mph on the oval with the gps.
                  • Troy1957
                    • Jun 2022
                    • 27
                    Peter what kind of amps are you pulling on both of those setups?
                    • Peter A
                      • Sep 2012
                      • 1489
                      I cannot tell you exactly, but it has a V2 T-180 esc and I am able to do a 5 lap + mill heat race with it on 5500 mah. So it has it has to be around 110A average draw. I have no datalog, nor do I care for one. What natters is how fast I get it to go and how many mah go back into the batt. I don't like going below 20% and it is right there with the setup.
                      • Troy1957
                        • Jun 2022
                        • 27
                        Peter which motor with the v2T180????
                        • Peter A
                          • Sep 2012
                          • 1489
                          Both. I was running a ZTW 200 but changed to the T-180 to lose a bit of weight.
                          • Troy1957
                            • Jun 2022
                            • 27
                            Awesome! Would this setup work on an outrigger like ml rsx380 36 inch???
                            • Troy1957
                              • Jun 2022
                              • 27
                              So I'm going to run the tp4060 1600kv with the T-180 and try the 45 mm props. Thank you for the info.
