Batteries for Zonda CHNL 5200,6200 or 9500MAH?
  • MidKnight
    • Aug 2021
    • 29
    Trying to make the choice between the 3 xxxxMAH battery choices. Whats your thoughts?
  • fweasel
    master of some
    • Jul 2016
    • 4291
    more mAh means longer runtime at the penalty of weight. I don't think the 9500 would even fit, besides being way too heavy. That narrows your choice down to two options. Personally, I'd rather spend the money on a better battery vs. more capacity for a given budget, i.e. a CHNL G+ 5000mAh
    Vac-U-Tug Jr (13mph)
    • MidKnight
      • Aug 2021
      • 29
      the 9500 will fit, but weight is up there for sure.
      taking the 2 similar sized mAh batteries, the G+ are heavier.
      【Speedrun】CNHL 5200MAH 22.2V 6S 90C
      Size 50X46.8X160mm
      Weight 813.5g (Including wire and connector)
      【speedrun】cnhl g+plus 5000mah 22.2v 6s 70c
      Size 60X51X146mm
      Weight 886g (Including wire and connector)
      • fweasel
        master of some
        • Jul 2016
        • 4291
        The weight difference between the two is negligible for this application. The G+ is a tested, and known good performer that will work great on a Zonda. They are what I would run if I wasn't using a Turnigy Panther.
