m34 raider trim tabs
  • a53hoop
    • Oct 2019
    • 65
    my first mono and more than happy how its turned out. only issue is it rides a little wet at speed. cog is at 9.5 in from trans and stinger has a tiny bit of up. i removed the trim tabs and she now almost a little too lose. the tabs are flat to bottom of hull and have no up adjustment.only mistake i made was installing parrallel to bottom of hull instead of about 1/16 inch above. would this be maybe the problem?? thks AL
  • Panchothedog
    • Oct 2015
    • 173
    That could have been your problem. You have bought a nice hull, now buy a nice set of ADJUSTABLE trim tabs and put them on 1/16" above the bottom of the hull. Between strut angel and tab height, you will have the ability to change ride attitude quite a bit. Non adjustable tabs are almost useless, if the initial setting isn't right your hands are pretty much tied.
    • a53hoop
      • Oct 2019
      • 65
      thanks very much for reply. would you have a recomendation on trim tabs i should purchase from ose. i have the black carbon fibre tfl brand with down only from ose. tks al
      • ray schrauwen
        • 9475
        You could drill out the mounting holes of your tabs and then they would have some adjustment.
        Nortavlag Bulc
