CF boat
  • Jonathan DeMaria
    • Jun 2020
    • 110
    CF boat
    I have a newly acquired boat that is carbon fiber. Will the reception be ok in it? The hatch is also CF. I have a futaba 3pv with the r304sb rx that i will be useing.
  • Johnc
    • Aug 2015
    • 199
    Antenna from receiver must be outside of the boat regardless of tx and receiver you use.
    If you use a gps to measure speed, it also needs to be mounted on the outside of the hull.
    CF blocks all reception that I know of.
    • Jonathan DeMaria
      • Jun 2020
      • 110
      So if my antenna is sticking out the back im all set?
      • koen
        • Mar 2020
        • 357
        keep in mind the antenna should not be shielded by the spray on the back of boat
        • fweasel
          master of some
          • Jul 2016
          • 4286
          Yep
          Vac-U-Tug Jr (13mph)
          • Brushman
            • Jun 2017
            • 51
            Yes, and te antenna should not touch the Carbon. despite of this precaution, you will have less range than with a fiberglass only boat. I see that with a Spektrum Radio.
