What should I set the the timing on for the TP 3650 -1680kv? Its a D-wind so I have it set at 3.25. I have upgraded the motor and ESC - TP 3650 and SK 180, but before I run I want to make sure the ESC is programmed correctly. Also, I have a doctorprops Tornado Prop that is 44mm. Should I run the stock 42mm first to make sure there are no heat issues? Thanks in advance!
-Fireman
-Fireman
