Picked one of these up yesterday and runs pretty well. Maiden run in chop was very stable and it reached 53mph. I'm sure in glass it will be closer to 60mph. Anyways, can anybody tell me how to remove the flex shaft? Is it just a matter of loosening the collar and pulling because this thing won't budge.
Flex Shaft for Pro Boat BlackJack 42
To answer your question Yes. And I'm pretty sure that's in the manual that came with it. But since we are men we don't need no stinking manuals . Think when I get back home I'll probably order the Black version. After loosening the collet if the flex won't come out easily lock a pair of vise grips on the nuts holding the prop on the prop shaft and lightly tap on the vise grips to pop the flex shaft out. -
It appears Proboat has added a plastic cover over the motor collet, likely to keep grease sling to a minimum. Pull that cover off, loosen the nut on the collet counter clockwise (standard threads), then pull the cable out the back. If it's not that easy, you can try twisting the cable at the prop end, clockwise, and pull at the same time. It's important to twist in the opposite direction the prop spins so you don't unravel the flex cable.Vac-U-Tug Jr (13mph)Comment
Turning the prop in the opposite direction while the motor collet stays in place, winds the flex cable tighter, just like it does under load.
You have to pull the hell out of it to get it out. The floating bushing is in the strut very tight and the bushing has to come out with the prop shaft because the BJ prop shaft is stepped down from 1/4 to 3/16 right at the bushing. Get some gloves on get someone to hold the boat and you pull it out. Sand the bushing around the edge so the next time it won't be as hard to remove. Good luck with it.Last edited by MADRCER; 05-31-2021, 12:41 AM.TFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17Comment
i had the same issue...i unbolted the 2 bolts on the strut and pulled the entire cable assembly out and dismantled it completely. i put the strut in the vise took a small deep socket and tapped on it until the bushing popped out. it looked like they assembled it with some type of adhesive on the bushing to keep it from walking back into the drive dog under load. whatever it was it came off with some cleaner and steel wool.Comment
Glad you got apart, I use 1000grit wet/dry sand paper to clean stuff up, but I think steal wool would work (wd40).
Apologies to Mr. fweasel for questioning his turning the prop in the opposite direction the prop rotates. He's right, I was on the road and trying to think it through and got it backwards. SorryComment
