I've stripped out my Miss Geico 36 to strengthen the hull following the development of stress cracks under the tunnel. I'll be doing the usual carbon fibre inlay, with particular emphasis on the centre tunnel where the batteries sit.
Considering everything is out of the boat, I figured it would be a good chance to upgrade. I've bought two TP 4060 1750kV motors, and will be running the boat on 6S. What would be the ideal ESCs for this? This boat will be used for sport running and some fast passes. I currently have DrProps 645/3 cleaver style props for this boat.
The specs of the TP's are:
Cont Power 3050W
Max 6200W
4-Pole
Max amp 213
Max volt 29
Max rpm 50k
I'm thinking to get the Swordfish 220A Pro+ ESC which is 2-6S, with 300A burst capacity. Or alternatively the Swordfish 200A Pro+ which is 4-8S and 240A burst capacity. The first has an inbuilt BEC, the second does not, however I'm thinking to run a separate UBEC anyway to take load off the ESC. These ESCs have data logging which will be nice, and the price of each is very similar. I understand higher voltage means less amp draw, but why would the burst amp draw of the 200A be quite lower than the 220A? Also planning to put on some extra Hifei caps.
Do you guys have any other recommendations for suitable ESCs?
Cont Power 3050W
Max 6200W
4-Pole
Max amp 213
Max volt 29
Max rpm 50k
