Loctite to use?
  • G.Rose
    • Apr 2010
    • 643
    Loctite to use?
    My wire drive came loose from my stub shaft. Which loctite do I use?
  • Darin Jordan
    • 8332
    Loctite 603
    Darin E. Jordan - Renton, WA
    • G.Rose
      • Apr 2010
      • 643
      Naturally Darren, I had the 603 plugged in to Amazon and changed it to 648. Well now I?ll have both. Thank you for answering
      • fweasel
        master of some
        • Jul 2016
        • 4311
        Both 603 and 648 are oil tolerant, 648 is better for tighter tolerances, 603 can handle looser fits. I use 648 for joining flex cables to stub shafts.
        • ray schrauwen
          • 9438
          Clean it out first.
          • Darin Jordan
            • 8332
            The 603 works well. Fills in the voids left by the cables strands, etc.
            648 would be good for doing wire-drives.
            • G.Rose
              • Apr 2010
              • 643
              Oh no! I canceled the 648 and the 603. I am trying to repair the wire drive. I guess I miss the race I don?t want to lose my prop
              • G.Rose
                • Apr 2010
                • 643
                I mean I got the 603 instead
                • Darin Jordan
                  • 8332
                  Gary, I use the 603 for both, so if you got that, you're good.
                    • 7990
                    When I ran mostly wire drives all I used was 603. The only joint which failed was made with compound more than a year past the expiration date.
