Zelos/Miss Geico motor swap question
  • Nick1979
    • Sep 2020
    • 118
    I am about to purchase a used 36" Zelos. I am already planning on swapping the stock motors with larger Leopard 4074. Does anyone know if the 4074 will fit with the stock motor mounts in the Zelos/Miss Geico? Thanks
  • fweasel
    master of some
    • Jul 2016
    • 4286
    Your question has been answered in the other thread.
    Vac-U-Tug Jr (13mph)
    • Darin Jordan
      • 8335
      It will fit, but that motor is going to add a lot of stress to the mounts, so eventually they will pop the mount loose. Motor is quite a bit longer so has more leverage against the mount when the hull bounces, etc... I also found that the mounts would rotate around a bit, even with the screws really tight. Once you get them located, might need to do something to help "stick" them in place.
      Darin E. Jordan - Renton, WA
      • koen
        • Mar 2020
        • 357
        If you swap the original motors for TP 3650 they will fit beter and are a massif improvement (you have to support the rear of the motor)you can find them at OSE
