Best 41-44? cat hull for 100mph
  • William77
    • Mar 2021
    • 4
    Got a question for anyone wanting to chime in. I have had several artr boats and am looking at building one exactly how I want it and was curious on what everyone?s thoughts would be on the best 41-44? Cat hull for around 100mph speeds. Looking at either 4082/4092 2000kv motors on seaking 180a escs on 6s. This is just a starting point and can be changed as needed. I was running this setup in a Zonda when the hull came apart. Just
    Looking for something strong. I can even reinforce the hull if there is a good one that handles well but needs some extra strength. Just want to get some ideas. I have been looking at the MHZ Mystic 1140 but am open to other suggestions.
    Thanks I?m advance!
  • vvviivvv
    • May 2009
    • 1082
    For straight line speed HPR115 or Mhz Mystic will probably be your best bet around that size. theres a 114 for sale in Europe that has SSS 4092 2140KV speed 155km/h which is just under what you want..
    999 Euro for hull and hardware...
    Uk SAW record holder
    • vvviivvv
      • May 2009
      • 1082
      It did have 280amp MGM ESC...
      • William77
        • Mar 2021
        • 4
        Thank you for the info, will check it out!
        • William77
          • Mar 2021
          • 4
          Do you have a link to the listing? cant seem to find it.
          • vvviivvv
            • May 2009
            • 1082
            • TRUCKPULL
              • 2975
              You original post say's that you want to use 180A esc to acheive this speed.
              The boat listed used 280A ESC's. witch are NOT included in the sale.
              180A ESC's on 6S will give a MAX wattage of about 3960W
              You motor;
              TP 4060 40mm X92mm - is 3050W to 6200W
              TP 4050 40mm X82mm - is 2350W to 5000W
              I would say larger ESC's are in order.
              LJ
              • William77
                • Mar 2021
                • 4
                I was afraid I was a little small on the ESCs, thanks for the confirmation.
