Beginner help
  • Bwhitmore42
    • Jan 2021
    • 4
    Beginner help
    I recently purchased my very first RC boat, it is the TRAXXAS Spartan and after running it a handful of times the drive cable twisted in half and broke. I installed the upgraded parts and took it out to test and now the prop only goes forward, I lost reverse is there programming or something I need to do to fix this?
    Try resetting the transmitter to the factory defaults.
    • Bwhitmore42
      • Jan 2021
      • 4
      Ok thanks. I?ll be home later to try that
      • Peter A
        • Sep 2012
        • 1488
        You don't really need reverse. If you have been using it then that may be why you broke your flex shaft, they are only designed to run one direction. Anything more than slow in reverse will damage or break flex shafts.
