Anyone out there have any preferences on any of the water pickups that OSE offers? It's going into a flat bottom drag boat. Thanks!
Thru hull water pickups
Tags: None
location, internal obstructions, and a clean installation are more important than the exact model. They need to go far back on the hull where they'll always be in contact with water when the hull is aired out. Close to the keel on a V-bottom and as low on the sponsons as possible on a cat.Vac-U-Tug Jr (13mph) -
Thanks for getting back to me. I've used the Octura pickup in the past and it worked well enough, but if there is a better one available, I'll give it a try. Thanks again.Comment
With a flat bottomed boat at speed you are unlikely to have any one part of the hull in the water consistently, I would look at a rudder blade pickup or a prop wash pickup instead.
If you really must have a through hull pickup, I would recommend making your own, a simple alloy or brass tube intake is much more efficient than any of the commercial offerings I have seen, so you will get bigger gulps of water whenever it touches the water.Paul Upton-Taylor, Greased Weasel Racing.Comment
If you really must have a through hull pickup, I would recommend making your own, a simple alloy or brass tube intake is much more efficient than any of the commercial offerings I have seen, so you will get bigger gulps of water whenever it touches the water.Comment
Spotted this design at Performance.Attached FilesOtto RC MarineComment
