Plywood sheeting for ML Boats scale hydros?
  • jingalls007
    • 1015
    Is there a company that sells sheeting kits for ML?s standard hydros? Or do you need to order the plans from Newton and cut the sheets yourself?
  • 1coopgt
    • Feb 2019
    • 414
    Someone will come along with the answer. I thought you could buy the kits/sheeting from ML. You kind of need to dig through the ML website a bit. I remember reading about buying sheeting there and there was also something about Newton mentioned also. I went with a fiberglass hull instead of going with a wood kit. Good luck with your future build.
    • meangenesracing
      • Jun 2012
      • 1158
      Mike has the sheeting you can buy along with the kits you just have to cut to the shape you need
