SonicWake 36 ESC
  • Crackers55
    • Nov 2020
    • 11
    SonicWake 36 ESC
    Can anyone tell me what they are setting the timing at for using 6s, everything else stock as received ?
    The manual for the Dynamite shows 18.75 degrees, which seems like a big increase over the factory setting for 4s of 7.5 degrees!!
    obviously I don?t have a good understanding of the timing topic
    Advice will be greatly appreciated, as I don?t want to damage anything
    thx
  • Nick1979
    • Sep 2020
    • 118
    I think timing has to do with the the wind and poles of the motor, not the battery combination used. What exactly are the motor's specs?
    • Crackers55
      • Nov 2020
      • 11
      All I have is : 1900 kv, 4 pole, brushless
      looking for Wind type
      • Capt'n Crash
        • Mar 2015
        • 166
        The stock Dynamite 1900Kv motor in the Sonicwake 36 is a D wind. The optimum timing for it is is 7.5 degrees for 4s or 6s. Anything higher will only create excess heat.
        • Crackers55
          • Nov 2020
          • 11
          Sonicwake36 Programming
          thank you
          • Capt'n Crash
            • Mar 2015
            • 166
            You are welcome.
            Some will tell you that the best timing for a D wind motor is 0 degrees but I was able to confirm with the boat's designer Rafael that the best timing for this particular motor is in fact 7.5 degrees.
            I also found the stock 44mm 1.6 pitch prop was a bit too much for this boat on 6s so I opted for a 42mm 1.3 pitch prop that had not been detounged and was very happy with the overall results.
            Happy SonicWaking
            • MarkF
              dinogylipos.com
              • Mar 2008
              • 979
              Anything above 0 timing on a delta is creating heat. This is from Neu motors and not a boat designer.
              • Nick1979
                • Sep 2020
                • 118
                I have to agree. I have a D wind motor and had the timing at 0. Just for an experiment I tried at 7.5 and everything was so hot - both the ESC and motor. I couldn't hold my finger for more that a few seconds on the ESC. So, stay at 0.
                • Capt'n Crash
                  • Mar 2015
                  • 166
                  Gentlemen, I agree to disagree but only for this particular motor as it is not made by Neu. I also have a few SSS D wind motors in my FE boats and all are set for 0 degrees timing. Initially I thought 7.5 degrees timing for the stock Dynamite motor was not correct so I set it to 0. I didn't see any difference in RPM or temperature with my temp gun between the two settings but for some reason the boat would go into early LVC on 0 degrees so I set the timing back to 7.5 and the problem went away. Motor temp after a 3 minute 30 second run is about 115F so it's not running hot with the higher timing.
                  The boat's designer indicated he was getting the optimum timing information from the ESC manufacturer for this particular motor/ESC combination.
                  For those that wish to read the designers reasons for the 7.5 degree timing you can see my question to him on the subject in post 376 and his response in post 379 over on RC Groups.
                  • MarkF
                    dinogylipos.com
                    • Mar 2008
                    • 979
                    it makes no difference who makes the motor. Adding timing advance adds to the load of any motor. it might not always be obvious when you add timing but it's there and increases amp draw however little or big it might be. In that article he says the esc uses 0 timing and advances up to 7.5 if the esc thinks it's ok to. That's auto timing and not the same as setting your esc to 7.5 where it always stays at.
                    • Capt'n Crash
                      • Mar 2015
                      • 166
                      Hi Mark. I agree with what you are saying but then why does the stock boat come with the esc default timing set at at 7.5 degrees instead of 0? From what you are saying 0 would be the logical default timing choice. Are Proboat and Hobbywing just wrong about this choice of 7.5 degrees default timing?
                      • Crackers55
                        • Nov 2020
                        • 11
                        Can you comment on using an octura x440/3 ( 40 mm x 1.4 ) on the sonic wake 36 with stock motor and sonic wake 180 esc, dual pick up rudder
                        thx again in advance
                        • MarkF
                          dinogylipos.com
                          • Mar 2008
                          • 979
                          It says in the article that it uses auto timing that starts out at 0 and adjust up from there to 7.5 Maybe they think there being slick and making your boat faster.
                          • Capt'n Crash
                            • Mar 2015
                            • 166
                            Honestly with out a GPS installed I couldn't visually tell the difference in speed between 0 and 7.5 but marketing is everything these days eh?
                            • Capt'n Crash
                              • Mar 2015
                              • 166
                              Crackers55 the x440/3 is a very good prop for this boat. I tried a Doctorprops 440/3 which is very similar but has less tongue. Much more stable on the water than with stock prop and no overheating with stock single intake rudder.
