Twin mono ruder set back
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7128
    Anybody have experience with rudder setback?
    I assume that screw separation should be minimal, and rudder should bare some perfect distance back.
    Boat is baby sv43, I?m thinking of having 48-52mm props 1/2? separation, set back from transom 3.5? or so and debating on how much distance between props and center mounted rudder... 2in? 3in? More, less?
    Please, respond if you have experience and/or data to support recommendation.
    Thanks
    Jesse
    "Look good doin' it"
    See the fleet
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7128
    Nobody?
    See the fleet
    • 785boats
      Wet Track Racing
      • Nov 2008
      • 3169
      Hi Jesse.
      I have only built one twin mono. A 44" Wasabi.
      I don't know if the setup is optimum, so I was a bit reticent to make any suggestion as I thought others with more experience would have by now.
      The struts I used placed the leading edge of the props at 2-1/4" from the transom.
      The rudder leading edge is 4" from the transom. The longest standoff bracket that I had at the time. Not much of a gap between the trailing edge of the props & the rudder. Should possibly be more.
      Here's the thread if it is any help.
      https://forums.offshoreelectrics.com...ghlight=wasabi
      Cheers.
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7128
        Hey Paul, thanks for chiming in!
        Man, what a beast! How did she feel while driving? Turns, straights, in the air?
        See the fleet
        • 785boats
          Wet Track Racing
          • Nov 2008
          • 3169
          It actually feelt pretty good in both the turns & the straights. Although I didn't turn too tightly around the bends.
          The driving in the air was a bit anxious. but she kept running.
          Unfortunately I haven't run it much since then. The offshore class that it was built for, never really got off the ground at our club.
          Motors & ESC's were robbed for other projects.
          • Jesse J
            scale FE racer
            • Aug 2008
            • 7128
            What was actual distance between prop shafts?
            and it looks like the rudder was about an inch behind the back of the props?
            See the fleet
            • 785boats
              Wet Track Racing
              • Nov 2008
              • 3169
              The shafts are 2.5" apart.
              The leading edge of the rudder is almost level with the trailing edge of the props.
              As I said, it should probably be a bit further back, but I have no idea what the optimum distance would be.
              Cheers.
