?S? bend in stuffing tube?
  • jingalls007
    • 1015
    Yay or nay? Is friction a concern?
    Thx doodes!
    While most of my boats built in the 20th century used S-bends, most I have built since then have a J-bend. Is a J-bend better? All I can say is that both worked well for me, with the J being easier to install in most (but not all) builds.
    • jingalls007
      • 1015
      Thanks Jay!
      Unfortunately a J-bend won?t work in my application without butchering the hull and canopy.
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7116
        If you are doing a single, then probably doable.. but I’ve seen twins be more than twice the challenge. It is tough enough getting two drive trains to perform close to equally and the stuffing tube is the biggest wild card IME.
        The last S bend I saw was in a twin cat and one side kept getting considerably hotter than the other, which made trouble shooting even more mysterious. But then again as Jay reminds us, YMMV.
        "Look good doin' it"
        See the fleet
        • jingalls007
          • 1015
          Jesse, this is a single. And late last night I figured how to get away with a J-bend 😎
          • T.S.Davis
            • 6220
            I've not had much luck with an S bend. I typically will keep fiddling until I can find a way to make the J work. Tip the motor. Move it. What ever. Every build has it's own challenges.
            Noisy person
            • Norwest
              • Mar 2014
              • 165
              Go to Paul Pachmayer in tips and info on stuffing tube build. There will tell you how to tilt motor for proper alignment. I use a liner which should be a tight fit so it won't turn.. Now if real tight, just sand liner to make it slide in easier. Less noise with liner. I tried straight shafts and worked out easy, just did it for the h^^^ of it and never looked back!
              • jingalls007
                • 1015
                It?s the 71mm Plettenberg motor That gave me a tough time. But I got it sorted.
