Tp 5680
  • meangenesracing
    • Jun 2012
    • 1164
    Tp 5680
    which wind for a 8s 2p 10,000 mah Backlash the 6D. 970 KV or the 3Y 1170 KV. Whats the best option? Thanks
  • MarkF
    dinogylipos.com
    • Mar 2008
    • 979
    I run the 5680 650KV on 10s in my insane cat and mono. If you want to run a gas size prop then you need to lower your KV. Spinning the snot out of a little prop doesn't work for gas size boats in heat racing. If your running in glass by yourself then that's different. I would recommend the 970kv for 8s just so you can run a bigger prop.
    • TRUCKPULL
      • 2975
      Eugene
      I thing the first question should be, what do want to do with the boat? Race Oval, Run oval or Straight Line Speed?
      Larry
      • photohoward1
        • 1611
        I have always been a fan of Lower KV and Bigger Props. About 24-25k RPM and 1/4" props. So may choices of props. 2 of my big boats are running Dasboata 7414/3 pitched to 1.5. prop. One is on my R42 with a Lehner 3060 about 650 kv. 10s. 72mph. For racing you may wan to slow it down a bit though. How agile is that throttle finger?
        • meangenesracing
          • Jun 2012
          • 1164
          Originally posted by TRUCKPULL
          Eugene
          Larry
          Want an oval boat and be able to race with gas hydros
          • MarkF
            dinogylipos.com
            • Mar 2008
            • 979
            If you want to race other gas hydros then I suggest a 650KV on 10s. I have gone to gas and have my setup for sale if your interested. It's a TP 5860 650kv, flier 400 esc, motor mount for 5" rails and a collet for the motor.
            • RaceMechaniX
              • Sep 2007
              • 2833
              I would second Mark's recommendation of the lower KV motor on 10S.
              Tyler Garrard
              NAMBA 639/IMPBA 20525
              T-Hydro @ 142.94mph former WR
              • meangenesracing
                • Jun 2012
                • 1164
                I'm still deciding on motor choice lehner or tp. How much you asking? Pictures please?
                • RaceMechaniX
                  • Sep 2007
                  • 2833
                  Go with the TP, you can run larger gas size props for half the price.
                  If you wanted a time trials or SAW type boat I would push you towards the LMT.
                  The TP is going to have more torque in a smaller volume and lower weight.
                  Additionally you will not need a huge ESC to power the TP at reasonable speeds.
                  While a 3040 size LMT can run equal speeds, you will need smaller props to do so and as Mark pointed out in rough race water small props are a disadvantage.
                  A 5680 is $250 with a cooing sleeve. An LMT 3040 with cooling jacket is double that cost once you include shipping from Germany.
                  -Tyler
                  Last edited by RaceMechaniX; 10-19-2020, 09:21 AM. Reason: Incorrect price on 5680
                  Tyler Garrard
                  • MarkF
                    dinogylipos.com
                    • Mar 2008
                    • 979
                    Correction a 5680 is $250. :) I will take $450. for my setup. I also make the batterie's for this kind of setup. I can make you 5s 10,000 or 12,000mah packs using my 65c, 70c or 80c formula.
                    Mark
                    dinogylipos.com
                    • meangenesracing
                      • Jun 2012
                      • 1164
                      Mark
                      dinogylipos.com
                      Mark, that's a fair price but I may want to buy new. On the lipos for the 5s 10, 000 mah whats the dimensions and price please
                      • meangenesracing
                        • Jun 2012
                        • 1164
                        A 5680 is $180 with a cooing sleeve. An LMT 3040 with cooling jacket is triple that cost once you include shipping from Germany.
                        -Tyler
                        Tyler, I value your opinion so I will go with the TP motor and save some $ also
                        Thank you, and to everyone who replied
                        • MarkF
                          dinogylipos.com
                          • Mar 2008
                          • 979
                          86x45x162 $192.00 Remember you will need to buy everything you see in my pic.
                          • meangenesracing
                            • Jun 2012
                            • 1164
                            What's the Mah. And weight of these 5s packs? I'm very interested in 2 of these for my backlash
                            • MarkF
                              dinogylipos.com
                              • Mar 2008
                              • 979
                              10,000 65c mah and 1160g There may be a set of these available because a customer ordered them but now thinks they wont fit his hull. I should get my order this week or next and will let you know if they become available.
